how to download labview 2010?
A link to "download LabVIEW 2010 for Windows immediately" seems to be broken (http://digital.ni.com/src.nsf/websearch/D5F33DFEF6E349628625776C006A8E40?OpenDocument&node=node=2030...); it displays " Services Resource Center Error HTTP Web Server: Lotus Notes Exception - Entry not found in index"
Which link can I use instead?
E
(12,765 Views)
How did you get to that link?
Assuming your SSP is up to date and you have access to the SRC, you can get LV 2010 from here:
http://digital.ni.com/src.nsf/websearch/CF169B0C9F5AC8FD86257880005141E8?OpenDocument&node=node=2030...
and LV2010 SP1 from here:
http://digital.ni.com/src.nsf/websearch/D7E7157873E230FA86257880005141FA?OpenDocument&node=node=2030...
You can always find what is available by going to ni.com/src.
(12,756 Views)
nevermind
(12,751 Views)
Thanks, but again, the link in there seems to be broken: Download LabVIEW 2010 Modules
(http://digital.ni.com/src.nsf/title/FB76DB328E265F9D8625776C006573C6?OpenDocument)
E
(12,714 Views)
I can finally see where you are getting these links.  It appears the crosslinks are bad.  If you follow the links from the src main page to get to the items, it works.
LV2010 modules:
http://digital.ni.com/src.nsf/websearch/CE3E59FA252BC2A586257880005141E9?OpenDocument&node=node=2030...
LV 2010 SP1 modules:
http://digital.ni.com/src.nsf/websearch/815E5368FE6D4BA586257880005141FC?OpenDocument&node=node=2030...
(12,707 Views)
