how to display value in waveform chart
dear sir
i am using labview 7.0 with dsc module for scada.
 now i want to display the difference between two tags value in waveform chart. Also i want to display that difference value on y axis and system date and time on x axis continously. Also if there will change in that tag value then there should be reflection of that value on wavwform chart with system time. Really i am in trouble. please help me.
falgandha mohire
(3,768 Views)
Hi Falgandha,
What do you mean displaying tag values on a waveform chart?  If I understand your question correctly, you would like to display data corresponding to the system time on the x axis.  If that is the case, you may want to use the XY graph and send the system time to the x array.
I hope this helps,
Nadim
Applications Engineering
(3,731 Views)
Nadim,
Why would an XY graph be preferable to using a Waveform Chart where the "t0" is the time of the measurement?
I don't get it.
Ben
(3,727 Views)
Hi Ben and Falgandha ,
You are absolutely right, Ben- Sorry for the wrong advice Falgandha.
I guess my real question would be, what kind of results are you expecting while plotting on a waveform chart?
Nadim
(3,705 Views)
