how to display custom data in a file in a graphical form?
The file format is:
       T1Ch1Val0Ch2Val0Ch3Val0 T2Ch1Val1Ch2Val1Ch3Val1 ...
I want display the multichannel data on a Waveform Graph and the X-Axes display the timestamp(T1,T2...)
Who can tell me how to do it or give me some example? Tanks in advance.
btw: I am a beginner of labview.
Message 1 of 11
(2,718 Views)
The first step in solving this problem is to first read the data. In order to do that you need to specify the format of the data. What's the format of the timestamps? What's the format of the channels? What's the format of the values? What are you using to read the data?
I would recommend looking at the examples that ship with LabVIEW on waveform graphs as they show you how to write up a waveform graph. I suspect, though, that since you have individual timestamps you'll probably want an XY Graph.
Message 2 of 11
(2,697 Views)
Is the file a text file or is it binary? Are the values run together or are they separated in some well defined way? What separates the T1 group from the T2 group? Are the values in integer, fractional, exponential, or some other format?
After the data has been read from the file, parsing may be easy or difficult depending on the answers to the questions above. Once parsed it should be relatively easy to display the data.
Lynn
Message 3 of 11
(2,696 Views)
My guess would be that a couple of nested loops and the Spreadsheet String to Array primitive will help you do what you want, but I suggest you upload a sample file, so that we can give a real answer.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
Message Edited by tst on 07-17-2007 07:30 PM
___________________
Try to take over the world!
Message 4 of 11
(2,693 Views)
If you could post a typical dataset it would be very helpful also...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 11
(2,676 Views)
attatch is the sample data.
/* sample code simulated to generate the sample data */
#include <stdlib.h>
#include <stdio.h>
#include <time.h>
#pragma pack(4)
typedef struct _sample_data{
 double timestamp;
 int  c1;
 int  c2;
 int  c3;
}sample_data;
#pragma pack()
int main(int argc, char* argv[])
 int i;
 sample_data s;
 FILE *f = fopen("sample.data","w+b");
 srand( (unsigned)time( NULL ) );
 for(i=0; i<1024; i++)
  s.timestamp = i*1.0/1024.0; //the time interval is not constant in actual envionment.
  s.c1 = rand();
  s.c2 = rand();
  s.c3 = rand();
  fwrite(&s, sizeof(sample_data), 1, f);
 fclose(f);
 return 0;
Message 6 of 11
(2,657 Views)
Since your data is in a binary file you need to use the Read From Binary File function. Once you have the data you can graph it any which way you want. See attached for an example (LabVIEW 8.20).
Message 7 of 11
(2,646 Views)
Thanks for your help. Unfortunately my labview is 8.0, can't open the example.
Message 8 of 11
(2,619 Views)
Message 9 of 11
(2,611 Views)
Thanks.
If the data came from ehernet,i want to dynamic display the data in realtime,how to accomplish it.
Message 10 of 11
(2,601 Views)
