how to display a bmp in labview?
Highlighted
Another option is to use an open source image converter to convert to a supported format.  ImageMagick may fit the bill, since it can be called from the command line using LabVIEW.  You could probably call the DLL, as well.
This account is no longer active. Contact ShadesOfGray for current posts and information.
Message 11 of 30
(1,278 Views)
Highlighted
I can see that your picture is from a digital scope. Are you able to change the scope settings to export a more convenient picture format?
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 12 of 30
(1,264 Views)
Highlighted
thank your very much.
I want to try your vi and check its result. But its version are higher than my labview.
Can you please provide a vi for 8.5?
thanks
br
Message 13 of 30
(1,261 Views)
Highlighted
hi, Coq Rouge,
yes. but my oscilloscope is cheap type, so it don't support other format. just ask technical engineer.
thank your advice.
br.
Message 14 of 30
(1,262 Views)
Highlighted
hi, DFgray,
Can you give a example for it. I don't use dll or command line before.
thanks.
br.
Message 15 of 30
(1,260 Views)
Highlighted
Here's an 8.0 version:
Ton
My LabVIEW Ideas
Message 16 of 30
(1,242 Views)
Highlighted
It is so simple actually. You may use both a IE activeX controller or the .net picture box. Se my very crude example
Message 17 of 30
(1,232 Views)
Highlighted
hi Coq Rouge
thanks you.
Can you provide a vi for 8.5?
thanks.
br
Message 18 of 30
(1,211 Views)
Highlighted
yes I think so. But remember the example is very crude. You have to select the file you want to load before running.
Message 19 of 30
(1,202 Views)
Highlighted
Just a clarification from earlier...yes, Vision Development Module and part of the Vision Acquistion Software require a license.  However, the part needed to just display an image, NI-IMAQ, does not need a license.
Alex Person
NI-RIO Product Support Engineer
Message 20 of 30
(1,175 Views)
