01-11-2010 07:54 AM
01-11-2010 08:33 AM
01-11-2010 08:41 AM
Hi, TCPlomp
thank your very much.
I want to try your vi and check its result. But its version are higher than my labview.
Can you please provide a vi for 8.5?
thanks
br
01-11-2010 08:44 AM
hi, Coq Rouge,
yes. but my oscilloscope is cheap type, so it don't support other format. just ask technical engineer.
thank your advice.
br.
01-11-2010 08:45 AM
hi, DFgray,
Can you give a example for it. I don't use dll or command line before.
thanks.
br.
01-11-2010 09:30 AM
Here's an 8.0 version:
Ton
01-11-2010 10:02 AM
01-11-2010 11:38 AM
01-11-2010 11:50 AM
yes I think so. But remember the example is very crude. You have to select the file you want to load before running.
01-11-2010 04:02 PM
