06-04-2007 02:16 PM
06-04-2007 03:10 PM
06-04-2007 03:35 PM
Why do you need such a precise degree of precision? I cant think of a single real measurement which could need such a precise value. If you think about it you would need a huge number of bytes to store such a number and the calculation would be slow to use. The only time I have done such calculations were for school assignments which were purely academic in nature and had no real significants to real world problem solving. You could implement your own number using a string and make simple set of VIs which will manipulate the string as a number. this does work (in fact this was an assignment I did in c many years ago). Essentially you have a cluster with a string containing the digits and a signed integer which is the exponent. Make a VI called ADD, Subtract Multiple and Divide which acts as an ALU/math processor. It will be very slow put will allow for many digits 1000s or precision. Other than this academic solution I dont have an answer to handle such precise # of significant digits.
Paul
06-04-2007 03:46 PM
I can't think of a real world application either.
However, there seems to be a problem that when data is moved through multiple computers, some degree of percision is lost and we wanted to know if we could replicate the data percision loss using a single PC. The problem lies in trying to compare the bit input and output from different platforms.
Thanks for your replies.
