how to disable/restore network(LAN) I/O port ?
Conseils, Yes, I did (if you believed not, please help to list out the focus),  and used the same command line can control floppy disk driver, why keyboard and mouse not?
anything special as you said ? or would you wirte down a command line sample here to disable keyboard ? thanks !
but from hardware manager, I can see floppy disk driver disable item from right click menu except mouse and keyboard. Does it lead keyboard and mouse no disable function ?
Message 11 of 12
(786 Views)
It was just a thought....
You could just make sure that the system can power down the keyboard in the control panel as well.
My keyboard is likely to have a different ID as its a wireless device... can't say I recommend it though...
Message 12 of 12
(781 Views)
