Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
how to detect the abort excution button of labview
s function= sytem function :
basically something that works like this
one block but has three tasks inside :
in the first call we excute the starting task (do something like initilization) just one time
then we excute the running task (run forever) only stop if we hit the abort excution button
after that we call the termination task that will only excute one time than the program finishes
Message 21 of 32
(868 Views)
Hi thesara,
So you did follow my suggestion as written here?
Message 22 of 32
(865 Views)
@alexderjuengere wrote:
This is dangerous in the hands of someone as experienced as the OP because they don't yet understand what the abort button does and are highly unlikely to tie up the loose ends before aborting.
Bill
CLD
(Mid-Level minion.)
Message 23 of 32
(841 Views)
yes. it is not going to magically stop or unload a dll
Message 24 of 32
(806 Views)
If your teacher really want to use the "Toolbar Abort button" i'd Customize Windows apprearence, hide the Toolbar and make a fake one with a red button that just stops your loop. 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 25 of 32
(781 Views)
Maybe plug everything into one outlet and label the abort button accordingly!
Message 26 of 32
(766 Views)
This is the answer!!
Message 27 of 32
(739 Views)
It is, so here's your homework finished. An exact replica of the abort button on a pixel-perfect imitation of the toolbar. This is what your teacher asked for.
Certified LabVIEW Architect
Message 28 of 32
(726 Views)
Since edit mode seems to be part of the required "user experience" here (sigh!), once the fake abort button is pressed, the real toolbar will reappear and we suddenly have two. (I would actually take a screenshot of the toolbar, place it on the upper left of the front panel, and overlay various transparent buttons.) The code could be implemented as a state machine that runs when opened and goes back to an idle state (i.e. not edit mode) when abort is pressed, making the theatrics complete.
Chances are high that if they want a custom abort button, they also want the rest of the toolbar, such as a run button 😄
IMHO, this entire thread is just absurd.
Message 29 of 32
(661 Views)
Yes, OP can do what I did but replicate the complete toolbar and have it run on open.
But you are right, this is absurd.
Message 30 of 32
(594 Views)
