05-05-2011 10:41 AM
Hi people. I'm having a big issue here: i wrote a program to control an IP Camera. It's based on an ActiveX object, an library (format .ocx) that came with the cam driver. This program runs as expected on the PC, but when I deployed it to comactrio, it stopped woking because cRIO doesn't support ActiveX objects. Is there any way to run an ActiveX object from the compactRIO?
Thanks!!
05-06-2011 03:21 AM
The OS on CRio's is VXWorks so there's no ActiveX support. Try to use the internet protocol on the cRio realtime controller to control your IP camera.
br Christian
10-15-2012 09:31 AM
Can you give an example for that one!
I'm very appreciated to see it, thank you in advanced!
