03-03-2007 09:39 PM
03-03-2007 09:53 PM
03-03-2007 10:47 PM
Dear Mr. Steve,
I'm using LabVIEW version 8.2. After your suggestion, I looked at the tank simulation example but could not figure out how they have simulated the tank. Also, when I observed VI block diagram for the tank simulation VI, I found that they have used different blocks as TF and DBL. I would appreciate if you could guide me about the functionality of these blocks.
Thank you for your prompt response to my last post. I highly appreciate your help and kind consideration.
Amit
03-04-2007
03:37 PM
- last edited on
05-04-2025
06:38 PM
by
Content Cleaner
A tank control indicator is just a fancy looking numeric like the various slides or the thermometer control on the numeric palette. The fill options is set to fill to minimum. The valve and heater controls are just Booleans so they are set with a True/False. Before you start with students, maybe you want to start yourself at http://zone.ni.com/devzone/cda/tut/p/id/5054.
03-05-2007
08:44 AM
- last edited on
05-04-2025
06:38 PM
by
Content Cleaner
03-05-2007 09:13 AM
03-05-2007 10:20 AM
03-05-2007 10:30 AM - edited 03-05-2007 10:30 AM
Evan:
What is DSC? I did not see anything under Start/NI that fits. I am running Professional.
-Pete
Edit: DSC= Datalogging and Supervisory Control Module. I could not find this package on my PC.
Message Edited by AnalogKid2DigitalMan on 03-05-2007 09:36 AM
03-05-2007 11:05 AM
As far as I can tell you need either lookout or DSC to have the image navigator on your system. So Pete, is there a chance you have either? Check Add\Remove programs or MAX to see if the software is installed.
03-05-2007 01:52 PM
