07-16-2019 09:34 PM
I just study Labview for 2 months. I would like to create a periodic staircase, which I could control the time and amplitude of each step. What should I do?
I try to use simulate signal generation, but it only up or down. I prefer a convex shape waveform (similar to the picture shown below).
Sincerely,
Kathy
Solved! Go to Solution.
07-17-2019 01:26 AM
Hi kathy,
Your image shows some up/down steps in the signal: all you need is to create a waveform consisting of several rectangular parts…
Each step is defined by its amplitude and length: you can easily create a SquareWaveform for each step!
When your parameters are provided in an array you could use an autoindexing FOR loop…
07-17-2019 06:40 PM - edited 07-17-2019 06:41 PM
Hi Gerd,
Thank you for your reply.
I have tried your advice on Labview, but I don't know how to combine those square waveform together in one x-axis. Could you make a sample vi to explain it?
Sincerely,
Kathy
07-18-2019 01:20 AM - edited 07-18-2019 01:20 AM
