how to convert voltage reading from DAQ to physical value?
Below is the example VI from labview,
my question is, how to convert voltage reading to physical meaning, I multiply the data by 15 but the graph indicator still show voltage value, I tried differenrt data type but couldnt do it. I know my method is wrong, but can anyone help me fix my error? thanks
(2,742 Views)
The simplest would be to create a custom DAQmx scale in MAX and then tell DAQmx to use that scale when adding the channel to the task (input is on the buttom of the Create Channel VI).
(2,726 Views)
