how to convert numeric value to string value means if i enter the value 10 its shows ten in indicator
please help any one
(3,777 Views)
Hi rocker,
you need to write some conversion routines based on the language you want to use.
Or you need to search for routines already made for that purpose. I remember OpenG (or similar) already had such VIs…
(3,775 Views)
hai,
you have any attachments for that
(3,772 Views)
Hi party,
start VIPM and look for yourself for the OpenG add-on…
(3,770 Views)
yes open g has ,
Good Luck
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(3,759 Views)
hai,
without openG how i build that one.?
(3,732 Views)
Hi party,
you need to analyze your number value.
Then you split the number in its decimals and use case structures to concatenate a string from corresponding words…
 In general: you need to do some programming! 😄
(3,728 Views)
