how to convert excel file to txt ?
C'mon Felipe!
That's just RUDE to create a duplicate post - and so soon after the 1st post.
Negative Kudos
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 11 of 14
(827 Views)
Ok, this is an ironic answer - so don't take it personal - but it fits to your question:
You could unzip your xlsx file (since an xlsx file is a zip-File in the first place). That leaves you with a bunch of xml-files that can be counted as txt-files. Problem solved. Smiley Frustrated
Regards, Jens
Kudos are welcome...
Message 12 of 14
(824 Views)
And here a hopefully useful answer:
As already stated by other you could use one of these options to read you excel file (besides others):
  • Report generation toolkit that comes with LabVIEW.
  • Have a look at the ActiveX examples in the NI example finder
  • Have a look at some of the toolkit in the VIPM like XLR8 or Claudie_xlsx.
All these will allow you to read in an excel file. A conversion to a txt-file should be pretty easy once you have the cell-data inside of LabVIEW.
Regards, Jens
Message 13 of 14
(805 Views)
Hi Felipe,
Check the solution of this old forum.
Excel and Labview
https://forums.ni.com/t5/LabVIEW/Excel-and-Labview/m-p/3784666#M1067200
Hope it helps.
Isabelle Orlandi
Engenharia de Aplicações
National Instruments Brasil
Message 14 of 14
(760 Views)
