02-26-2015 01:16 PM
if i have for example binarystream 01001
and i want to represent the 1's by a duration for example 12 us each
and the 0's by 2us each
i want to be able to control the bit duration..is there anyway to do so ?
02-26-2015 01:47 PM
Yes it is possible, one alternative is with FPGA's, which type of hardware do you have?
02-26-2015 04:10 PM
i am not sure of exactly what you mean but i will try to introduce the problem
i am trying to send a bitstream where the 0's and 1's are as shown
and Tari is a value varying from 6.25us to 25 us
02-26-2015 04:24 PM
The question is where are these bits actually being generated? You need some sort of digital I/O channel to output this data on a wire. A serial port would not be capable of doing this.
02-26-2015 04:29 PM
USRP
i am pretty new at labview..and i am trying to use it to programm an RFID reader transmission
and i have a task now to generate random bits and use the PIE scheme above to display on a graph
and be able to control the time interval of the bits
i hope i am more clear now
02-26-2015 04:56 PM
I'm not familiar with USRP. But there is a forum dedicated to it. You might find help there more quickly.
