how to control RFID reader by TCP
    I need get data from RFID reader, I realized the connection to the reader by "TCP listen.VI" and got the data package. Now I want to control the reader, so I should send commander to the reader first, the question is that I do not know how to send a command to control the reader, and what the command should be. I am a novice, I hope you can help me, thanks!
    Attached is the VI and instructions from the RFID company!
Message 1 of 10
(9,174 Views)
Accepted by ppcas
Here is a very basic example of how you could get the gain back from the RFID reader. Using a similar approach you could implement the rest of teh protocol as defined in the spec.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 10
(9,160 Views)
Thanks for you reply, but I could not open the attached VI, could you help me to convert it to labview 8.2
Message 3 of 10
(9,154 Views)
Here it is.
This is a very basic example. It is just a simple illustration how you can implement the protocol for the RFI Reader. You should remember to used a typedef for the cluster definition. I would also create separate VIs for each operation defined in the spec. This will get you started though. For reading back the tag data you will need to look at the length value in the packet data to determine how much additional data will need to be read. You can define a different cluster for that data.
Mark Yedinak
LabVIEW Champion
Message 4 of 10
(9,147 Views)
Thanks again! It's very useful for me, a new to labview
Message 5 of 10
(9,143 Views)
Hi Mark, do you have the VI of getting the tag ID or other related VIs, Thanks!
Message 6 of 10
(9,128 Views)
No, I do not have this vi. I worte the above as a quick example of how it can be done. I am more than happy to answer specific questions but I am not willing to act as a free programmer. Besides, adding the code for the additional messages would be a good learning experience. If I simply write the code it will not help you to learn LabVIEW.
Mark Yedinak
LabVIEW Champion
Message 7 of 10
(9,088 Views)
Hi Mark, can you suggest me some useful link for the startup of TCP/IP communication. I'll be thankful.
Naqqash
Message 8 of 10
(8,867 Views)
Look at the examples that shipp with LabVIEW. They are a good starting point. Simply search for TCP.
Mark Yedinak
LabVIEW Champion
Message 9 of 10
(8,855 Views)
Hi Iam trying to interface a RFID module to labview, communication between RFID device & labview its happening .
i need suggestions which mode i need to use in labview for Reading the data from the Tags.
i have attached the image of RFID working in the Vendors app.
Message 10 of 10
(6,076 Views)
