03-19-2012 09:16 AM
i am using lakeshore336, i need to set a setpoint temp and increment that value by a desired value in each execution.please help me..
03-19-2012 09:22 AM
What have you tried? All that you need is a shift register, an addition function, and a comparison to see if you reached the max value. Another simple method is to use the Ramp function to create an array that you pass into a for loop.
03-19-2012 09:36 AM
can you send me sample program, i am new to labview
03-19-2012 09:41 AM
In that case, you should read: http://www.ni.com/gettingstarted/labviewbasics/
Then post your VI if you're still having problems and we'll give you some pointers/specific help.
-CC
p.s. Look at the examples that ship with LabVIEW for a good starting point
03-19-2012 09:49 AM
i got it thanks.........
