I am unsure on how to add limits to my program so that labview tells me when I am reaching the design limits of the machine. I am controlling an actuator that is loading the specimen and once I reach a certain load, the actuator is supposed to stop. Is there a way to add limits into my program so that when I reach 3/4 of the design load then my application stops the actuator? Currently I am using the mask and limit test but I do not think this is the best way to complete what I would like to do.
Also is there a way to program when my actuator stops without having to press the STOP button. Can it be programmed to stop once it has reached a certain load, or programmed to load in increments? For example I would like to load the specimen until 10lbs and then stop the actuator, read the associated strains and then continue loading to 20lbs.
Jena
