how to check the out is in fraction
Hi have output in 17.22 i want to check is there is value in point form i want connect it to true case if its a number i will pass to false case structure..how to do this?
Message 1 of 9
(3,150 Views)
Jeyanthi,
You'll need to rewrite question again.  Neither your subject line nor your message make any sense to me.
The troublesome phrases:
"the out is in fraction"
"output in 17.22"
"value in point form"
"connect it to true case"
"if its a number I will pass to false case"
Message 2 of 9
(3,149 Views)
Hi Jeyanthi,
   Find the vi to find fractional number,hope it solves your problem Smiley Happy
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 3 of 9
(3,143 Views)
can i get an 8.0 example.. plz
Message 4 of 9
(3,136 Views)
Accepted by topic author jeyanthi
Find the vi in LV8.0
Balaji PK (CLA)
Message 5 of 9
(3,133 Views)
Hi Jeyanthi,
Is your problem solved? If so please mark the post (Whichever you think is the best solution for your query). This will help others facing same problem and looking for a solution.
Balaji PK (CLA)
Message 6 of 9
(3,108 Views)
Careful...
Message Edited by jcarmody on 03-30-2009 05:25 AM
Jim
Message 7 of 9
(3,087 Views)
Hi jcarmody,
     I also know it is unwanted, but in the post jeyanthi mentioned i want connect it to true case if its a number i will pass to false case structure..how to do this? . So only i try to mention wire the boolean to the case structure and do required operation. anyway thanks for the comments.
Message Edited by Baji on 03-30-2009 04:03 PM
Balaji PK (CLA)
Message 8 of 9
(3,080 Views)
Arrrggggghhhhh; you're right!  I apologize.
Jim
Message 9 of 9
(3,076 Views)
