06-19-2007 12:16 PM
06-19-2007 04:44 PM
06-20-2007 11:00 AM
Hi Jex,
I'm not sure I understand what you are looking for. You said that the problem with the other thread was that it was "designed under LabVIEW." Are you trying to program in a different language?
The thread that Dennis pointed you to should get you started with the programming.
As far as checking the output, you can always route the signal externally to another input and measure the signal. I'd recommend measuring it with a counter task.
06-20-2007 11:29 AM
06-20-2007 11:39 AM
Hi Jex,
Yes, changing the time delay should change the pulse width of the signal. It sounds like that should work for you. Let us know how it goes.
06-20-2007 11:46 AM
06-20-2007 12:35 PM - edited 06-20-2007 12:35 PM
Message Edited by Luke G on 06-20-2007 12:37 PM
06-28-2007 10:19 AM
06-29-2007 03:59 PM
06-30-2007 08:41 AM - edited 06-30-2007 08:41 AM
Message Edited by jex on 06-30-2007 08:45 AM
