how to change x-axis time setting of look up table in control design and simulation loop.
hello ,I am developing  a labview programme based DAQ application to acquire signal of minimum 50 channels.using NI PXI 1031 chassis and multifunction DAQ card NI PXI 6225.I wrote programme and in that I have used look up table VI within control design and simulation loop.As I am acquiring CCS temperature sensor data in the form of voltage and wants to change this voltage signal to its corresponding temperature value given in look up table. I achieved that but I am facing problem in the simulation time of the look-up table.data acquistion time is not match with my computer time. X- axis time setting is not change of graph used for plotting the output of simulated data. It has some default value which is fix.So I want help ,that how can I change the time setting of look-up table VI or time setting of control design and simulation loop.
(2,397 Views)
Hi mbskk,
first: when you want to attach images then please attach images (JPG, PNG). Don't attach some proprietary document formats! Or even better: attach real VIs!
- Don't use the CS loop. Use a standard while loop.
- Use a standard point array and the Interpolate1DArray function to realize a LUT.
- Don't convert an array to a cluster to be able to add up the array elements. Use ArraySubset and AddArray.
- You need to set the waveform timestamps correctly, when you want to have current time on your chart. This isn't done automatically by the second function in your "Look-up table" marking…
(2,391 Views)
sorry  but I don't understand why you are saying that I don't use CS loop when already there is look up table VI, than why I should use standard point array and the Interpolate1DArray function to realize a LUT.and I have set timestamp of correctly but that's I am saying that its not change when I go in x-axis setting and try to change it.
(2,340 Views)
Hi mbskk,
It is simply overkill for that purpose (and a lot of other RubeGoldberg too). Did you check all those DAQmx example VIs coming with LabVIEW? They never use any CS loop…
Because it is the very same operation - with no additional overhead…
Where did you do so? I cannot see this…
You use charts and so will not have many options to set their x axis…
(2,321 Views)
