how to call sub-vis with a click of a button?
Is there any block that functions llike "System Exec" ?
"System Exec" calls only .exe file.
I need a block that can call a Sub-VI.
TQ
Message 1 of 12
(5,134 Views)
Check out the Call By Reference Node.
Message 2 of 12
(5,123 Views)
A simple polling loop can do this.
So can an event structure:
- tbob
Inventor of the WORM Global
Message 3 of 12
(5,110 Views)
Attached are 2 test VIs.
Program3 is the main VI which calls Dialog.
The programm should work as described:
When Enum = wait, nothing happens.
When Enum = Show Dialog, the Dialog.vi will be executed and display the random generated value. Enum's value will then change back to "Wait".
I can then close the dialog.vi and reopen it again by selecting "Show Dialog"
Basically, i need to call the Sub-VI and it must run independently from the Main-VI.
Thank you.
Message 4 of 12
(5,099 Views)
oops, here are the 2 VIs.
Message 5 of 12
(5,092 Views)
Check out this thread.  There is an example of code that launches a specific vi (from a list) and waits for the vi to complete.  When the launched vi finishes control is returned to the main vi
Is that something like what you want ?
"Should be" isn't "Is" -Jay
Message 6 of 12
(5,080 Views)
not really.  for my case, the subVI should act like a pop up screen, and run continuously until i close it. And can be call out again when i need it.
in my previous program, my sub Vi is being called and close continuously.
Message 7 of 12
(5,071 Views)
Hallo tbob,
i tried using the 1st example that u show me (the one with the case structure). but it doesnt solve my problem, because when i close the sub Vi, i want my main program to continue running. Is that anyway, that when i call the SubVi out and it will run independently as long as my main program is running?
Message 8 of 12
(5,067 Views)
fmpfmpf wrote:
Hallo tbob,
You need to mention these things if you want a correct solution.  Here is a corrected version of your Program3 vi.  You don't really need an enum.  You could use a simple boolean switch set to Switch When Released.
- tbob
Message 9 of 12
(5,046 Views)
Here is a way to do it with the example I first showed.  I don't know why you could not get it to work, it does.  I changed your diaglog vi to have a stop button to close its window.  Closing the subvi does NOT close the main.
Message Edited by tbob on 05-18-2010 04:46 PM
- tbob
Message 10 of 12
(5,041 Views)
