how to calculate the phase difference between two square wave (acquired from two channel in one DAQ)
Hello everyone ,
 I need a quickly help that as below :
I am trying use PCI-6220 to acquired six signals from one rotation encoder (channel A, channel B,channel Z ,and their non-signals) .The encoder out signals will be square wave and 4000pulses per revolution. I set it rotation at 300rpm speed. I need show every square wave of six out channels in waveform and measure the A-B phase difference to check if the value is correct (designed value should be 90deg) .
I have no idea how to measure or calculate the phase difference of two square wave base on synchronizate to acquire these two square wave from two channel on the PCI-6620....
Anyone can give a idea how to calculate the phase difference with two square wave ?
Thank a lot and Thanks again...
Tim
Message 1 of 11
(10,094 Views)
Tim,
Locate the rising edges of both A and B by sample array index numbers. Find the difference in index for successive samples of A. Find difference in index for an A edge and the next B edge. Divide by the difference in A. Result is fraction of period. To get phase in degrees multiply by 360.
Lynn
Message 2 of 11
(10,088 Views)
Lynn,
Thank you for your response , But I have a little confuse on how to locate the rising edages of both A and B by sample array index numbers. can you give me a program that  demonstrate what you show me ...Please.
Thank you very much
Tim
Message 3 of 11
(10,080 Views)
Tim,
What version of LV are you using?
Lynn
Message 4 of 11
(10,068 Views)
Lynn,
   Labview8.2 full .
Thanks again
Tim
Message 5 of 11
(10,065 Views)
Tim,
Here is a simple rising edge detector for one channel.
Lynn
Message 6 of 11
(10,057 Views)
Thank you very much !!!
Thanks again .
Tim
Message 7 of 11
(10,053 Views)
hi, sorry to bother, but my labview version is 8.0, so i cant open this VI 😕
i wonder if you guys cant post the picture (jpeg or whatever) of this vi
thanks a lot
see'ya
Message 8 of 11
(10,038 Views)
Here is an 8.0 version.
Lynn
Message 9 of 11
(10,032 Views)
Hi Lynn,
Can you also add further for finding phase difference from two channels ?
Thanks in anticipation.
Message 10 of 11
(7,042 Views)
