how to build a Single Point (On-Demand) Edge Counting with Pause Trigger
Hi, I am building a clock as shown below. It is as called "Single Point (On-Demand) Edge Counting with Pause Trigger".
clock.PNG"
I have problem to find example code. Up to now I can only build an edge counter without trigger controller as below. Could anyone help me out?
(1,317 Views)
Accepted by topic author haitaoli7036
Have you seen the Count Edges LabVIEW example? It should be located in a location similar to this, C:\Program Files (x86)\National Instruments\LabVIEW 2013\examples\DAQmx\Counter Input\Counter - Count Edges.vi. This should be a good guide for your application.
Jason H
Automated Test Software R&D
(1,280 Views)
Thanks. It helps!
(1,258 Views)
