06-14-2013 12:35 AM
I'am attaching one VI.Here I 'am trying to combine three numbers from the termination part of the motor for finding the steps it rotated. So the numbers 165,166, 167 in the combination given in VI will provide me the necessary number.I need a help that if I plot the graph whenever the running command is there the system will give me zero in XY graph. I need to avoid that problem. So how can I do it.please kindly reply
06-14-2013 01:32 AM
You need to place the build array and associates stuff inside the case where good data appears and wire the array across all other cases unchanged.
06-14-2013 05:10 AM
this good data means what, please explain little bit understanadable or make sufficient changes and sent me the VI.
06-14-2013 05:20 AM - edited 06-14-2013 05:22 AM
Many output tunnels of your stacked cases are set to "use default if unwired". The default value for a numeric is zero, meaning whenever one of thise cases execute, you'll end up with zero (bad value) instead of a data received from the instrument (good value). If you wire the data array across all cases, you can leave it unchanged in the cases where no data appears (simply wire the array across untouched), but append new values where you get actual data (in this particular situation if the outer case is true and the inner case is false).
You've been working on this for weeks now and have not followed any advice given here. If this challenges you so much, maybe programming is not what you should be doing.
06-14-2013 05:22 AM
Good data means non zero data. Bad data is 0. Hope this is what he mean to say.
06-14-2013 05:25 AM
Please don't put words in my mouth! A zero can be good if it is received from the instrument and can also be bad if it is the result of an unwired output tunnel. The value is irrelevant.
06-14-2013 05:28 AM
I was guessing only by seeing the question as he says that he want to avoid 0.
06-14-2013 05:37 AM - edited 06-14-2013 05:39 AM
Please don't guess an answer before you have all the information. Look at his VI! Read the entire problem description!
If something has already been said, don't contribute redundant, useless and misleading information. That's just noise!
06-14-2013 05:48 AM
Ok will keep that in mind.
