08-09-2007 08:07 AM
08-09-2007 08:12 AM
I don't follow your requst.
Please post an image or code that illustrates your challenge.
The Picture Control thread contains links to many picture realted examples.
Depending on which version of LabVIEW you are using, the Annotations may also serve your needs.
Ben
08-09-2007 08:46 AM
08-09-2007 05:51 PM
I will forget I looked at your code.
Two ideas.
Use the plot>>>name property to set the plot names.
or
Read the final file, insert text in picture, save to file. There should be examples in the pciture thread I previously posted or in LabVIEW's built in help.
I hope that helps,
Ben
