how to Split an 1D array into number of sub arrays
Highlighted
hi all,
 i want to split an array into number of sub arrays at time. most of the time i am going through Split Array or Delete from array. but i am thinking that  by using these two functions i would make the vi a big mess. so please help me if anyone can ....
 Thank you
(2,305 Views)
Depending on what your goal is, Reshape to a 2D array might be the right tool. If you e.g. have a 100 element long array you can reshape it to a 10x10 and you'll have 10 'subarrays'. Smiley Happy
Else Array subset or as you mentioned Split in a loop is probably the right thing. If you e.g. want different lengths of the arrays you'll need to create an array of cluster having the 1D array parts as elements.
/Y
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
(2,279 Views)
You don't provide sufficient information to really help you. How are you splitting? Is there some regularity on the split points? What are you going to do with the parts? How many parts do you have at the end? How big are the arrays?
Can you give an example or show us your code? Does it currently work correctly but you are worried about performance?
If you just want to operate on a subset, you can leave the input array in place and use "array subset" top get a part of it at a time. No need to chop up the input.
LabVIEW Champion Do more with less code and in less time
(2,273 Views)
sorry for not providing the sufficient information. i want to divide an 1D  array into different arrays with same length.
(2,269 Views)
Then "Reshape Array" might be a good solution. And don't forget, there's also the function "Array Subset".
Regards, Jens
Kudos are welcome...
(2,262 Views)
... and what do you want to do with the resulting parts?
What kind of problem you are trying to solve. Where does the input array come from? What should happen to the parts later? What should the final output be?
(2,257 Views)
