how do i open a word document as a sub-VI?
i need  to use/open a word document or a web page as a sub-VI. All im able to do now is upload it as a text format and it dosen't look to presentable.
i have been trying the Active function and it dosent seem to work as i am not to familiar with it. i need suggestion to  overcome this problem
thanks
(2,997 Views)
Hey,
I have been trying to open a text document in a VI, but I can get it! How do you load a text document into a table or something? Not into a string though.
(2,987 Views)
To Pravin: A Word document and a web page are considerably different, so to display them you typicall need two different mechanisms, but you can use a web browser to "cheat" with the Word document. Note: Assuming Windows as the OS for remainder of discussion. To display a web page you can use the Internet Explorer ActiveX control, as shown in this example. To display a Word document you can still use the web browser and use the same "Navigate" method to load the Word file via the "file:\\" URL.
To Submeg: That is a completely different topic. Please start a new discussion.
Message Edited by smercurio_fc on 06-22-2007 09:43 AM
(2,971 Views)
to: smercurio_fc
i am not able to view the example you suggested. it sounds interesting pls suggest a different way.
i want to upload a word document or a repective web page can u pls suggest a solutioj
thanks
pravin
(2,954 Views)
Sorry about that - screwed up when entering the link. This is the example I was referring to. For an example using Word, you can take a look at this.
(2,940 Views)
