05-22-2009 09:58 PM
I am new to Labview. How do I create a VI?
Thanks for help
05-22-2009 10:37 PM
hi Trex600N
I hope you have installed labview. if not install it first. Then go to start>>National Instrument LabVIEW..
Then a window will get opend which will have title bar " Getting Started" .Click on "Blank VI"
here you go with new vi created. save it and progarm it.
Best of Luck
Gaurav
05-22-2009 11:21 PM
05-23-2009 01:46 AM
gak wrote:hi Trex600N
Best of Luck
Gaurav
LOL! I wish I could give more than one kudo! Too funny.
05-23-2009 08:47 PM
Thanks for reply. I meant to create a sub VI . I managed to learn how to create a sub VI last night.
Now, I would like to import a picture in to my front panel. How do I do that?
I tried to import a picture .bmp but it did not work? Any idea?
Thanks alot.
05-23-2009 09:08 PM
Have you checked the LabVIEW Help? It explains how to do this:
Import graphics for front panel backgrounds using either of the following ways:
- Right-click the scrollbar of a pane and select Properties from the shortcut menu to display the Pane Properties dialog box. On the Appearance tab, use the Background, Browse, and Position options to set a pane background image.
- Copy the graphic to the clipboard and paste it on the front panel. You also can select Edit»Import Picture to Clipboard and paste the graphic on the front panel.
05-25-2009 11:30 AM
what is funny ? i was trying to help.he dint mention that he wants to create sub vi.
Gaurav k
05-26-2009 04:09 PM
Were you able to apply the advice above? If you want to do this programmatically, see this KB http://digital.ni.com/public.nsf/allkb/BC9281DCFCBF7B5C862570120064362C?OpenDocument
Regards
Anna K.
