how do I get text value in column next to tree element?
I can only get elements from the left column...how do I read from other column.
For example if I want  "Version 1.0" i get the section1 tag, then the first child...and then?
thanks
(3,188 Views)
 Hi Diego,
try with this method
D. Beninato
(3,153 Views)
Thank you
in the mean time I came up with a similar solution.
What is the difference between the property and invoke node I used and yours? Maybe my version is more flexible because require a generic tree reference? But yours looks more simple and clear...
I'm not an expert of these functions I was just wondering about the theory beyond them and which is best in which case.
diego
(3,132 Views)
Sure, your version is more flexible because use a generic tree reference and it can change programmatically.
On the other hand it requires that you pass a wire and if you design a multiprocess programm this can be a problem for the parallelism of the processes.
D. Beninato
(3,124 Views)
