how do I dynamically assign the dimension of an array in a formula node?
I have an array inside a formula node whose dimension I would like to assign at run time. I tried the following, where s is an input to the formula node:
N = sizeOfDim(s, 0);
float64 myvariable[N];
But got the error message "formula node: index list expected".
If I say
float64 myvariable[1000];
it works fine, unless I happen to need an array that's bigger than 1000!
(4,520 Views)
Formula nodes cannot dynamically size arrays. This is a nontrivial thing to do in C. I recommend either always using a large array or build a dll for the computations (so you can get the fancy functions) and calling the dll from LabVIEW.
Jeremy
(4,520 Views)
> formula node:
> If I say
> 1000!
I'd recommend that you do this using the diagram. Set the array size on
the diagram using the Resize Array node and pass it into the formula.
Greg McKaskle
(4,520 Views)
Of course! Why didn't I think of that? 😉
(4,520 Views)
