how do I convert a deciaml input to a hexidecimal output in labview?
Can somebody please explain what seems like a simple conversion ?
I would like to convert a decimal input to a Hexidecimal output:
i.e input value of 20000
converting to a hexidecimal output of 4E20
hope you can help
AW
Message 1 of 21
(21,913 Views)
This just has to do with formatting. There is no actual conversion taking place.
Make sure your numeric is an integer (I or U representation), right click it and select Format & Precision and select hex from the list.
___________________
Try to take over the world!
Message 2 of 21
(21,908 Views)
Thanks, that seems to do the trick!Smiley Happy
Message 3 of 21
(21,905 Views)
Hi!
There are two simple ways to convert decimal to Hex.
1. just simply make your indicator format to Hex (I 32). Just right click on indicator and go to format and
    precision. Select data range and format.
2. Use convert decimal string to hex converter in string palet at block diagram.
Refer vi.
Kaustubh
VC (Pune)]
INDIA
Message 4 of 21
(21,888 Views)
I want to convert 16.234 to Hex Value. Kindly suggest...
Advance Thanks
Anil
Message 5 of 21
(20,440 Views)
Hi Anil,
           Are you looking for this one?
           See the attachment:
Thanks as kudos only:)
Message 6 of 21
(20,431 Views)
Hi danil,
some rework to adapt for non-English regional settings and preparation for more decimal digits:
Message 7 of 21
(20,422 Views)
Dear D Anil33
Thanks for reply
One of the example to communication they have given 16.000V - Hex = 0X00003EB0.  if we convert directly hex it will show 10..
I am little bit confused.
Message 8 of 21
(20,418 Views)
Hi Anil,
3eb0h is 16048d...
Could you tell more about the background of your question?
Is the device using that number using some scaling? Is your decimal float number scaled to a certain range? Then you would need to "pre-scale" your float and convert it to a simple (integer) hex number...
Message 9 of 21
(20,415 Views)
I want to communicate IT6800 Power supply through RS232 communication. total 25 byte String 26th is check sum.
Message 10 of 21
(20,410 Views)
