03-01-2004 07:46 AM
03-02-2004 05:20 AM
03-03-2004 08:24 AM
03-31-2009 12:01 PM
Can't you just copy the settings from the working drive using lenze epm module and put it on the second drive that is not working?
03-31-2009 12:17 PM
Do you know you replied into a thread that is 5 years old?
Copying parameters might work fine if you are trying to duplicate a drive to work with another identicaly motor. But the problem here was with the communication parameters for two drives on the same bus. One drive has to have those parameters modified in order to work. It sounds like the solution was given and the original poster said it worked.
