how display a subvi's front panel in a main vi's tab control?
Crossrulz I have used the sub panel to insert the sub vi but it is not a good way to make presentable gui because on the front panel of main vi it just displays the vi front panel completely. But I need a pop up window to run the sub vi.how can I do this.
Dave Brandt can you give me the front panel view of above block diagram?
Message 21 of 32
(1,265 Views)
If you need a pop up, then you just simply call the VI with it configured to display when called in the VI properties.
GCentral
Message 22 of 32
(1,259 Views)
You can just drag the vi snippet into a block diagram.
Message 23 of 32
(1,247 Views)
Crossrulz! here is my main vi. I want an icon like subvi onmain vi  front panel.how can i do this.
Message 24 of 32
(1,233 Views)
Brandt! I have done this. But in this case nothing appears on front panel.I need subvi window on front panel.
Message 25 of 32
(1,224 Views)
Run the main vi. Browse to any vi path in the path control. and select ok This will put the front panel of the selected vi into the subpanel control. You have to make you vi front panel size and subpanel container compatible for sizing. These are some advanced labview programing techniques and maybe you should get training.
Message 26 of 32
(1,190 Views)
So you want a button that looks like a VI icon on your front panel?  And when you click the button, that VI opens up?
Drop down a button, right-click on it, and select Advanced->Customize.  That will open up the control editor.  In here, you can add images to the button and some other stuff.  Once you have it looking the way you want, just use an Event Structure to wait for the button to be pressed and directly call the VI you want to open up.
GCentral
Message 27 of 32
(1,164 Views)
Thankyou crossrulz you made my day.
Message 28 of 32
(1,140 Views)
Can you tell me it is used for what purpose?
Message 29 of 32
(1,106 Views)
A subVIs inputs and outputs are defined by connecting front panel controls and indicators to the connector pane. That is six LabVIEW that you would learn by taking some of the free tutorials.
Message 30 of 32
(1,081 Views)
