how display a subvi's front panel in a main vi's tab control?
All Examples I've seen include a static path to the sub Vi.  Is there a way to do this assuming the Sub Vi is part of the project or exe build?
Message 11 of 32
(2,807 Views)
Yes, you can use Open VI ref with a path and have it completely dynamic. It causes some issues with building an .exe as the compiler doesn't know about such files and you'll need to add them to "Always include" or a included source code distribution yourself.
/Y
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
Message 12 of 32
(2,804 Views)
Got it. Thanks For the Help!
Message 13 of 32
(2,780 Views)
Can I display sub Vis on the front panel of main via such that when I click on any one of the sub vi ,it starts to execute.
Please help me to do this.
Message 14 of 32
(2,193 Views)
Do you really want a subvi or a plug in vi?  A subvi will effect the operation of the main calling vi and a plug in will run independent of the calling main vi.
Message 15 of 32
(2,184 Views)
I am doing data acquisition and needs to display voltages and currents graphs in two different subVIs, so accordingly what I should use plug in or sub vi? Main vi just contains sub vi or you can say welcome to GUI window.
Message 16 of 32
(2,176 Views)
Use a subpanel to insert the subVI's panel.  But that subVI should be running in parallel of your main loop.  It should have its own GUI control and/or receive commands from the main loop.
GCentral
Message 17 of 32
(2,165 Views)
Any example to elaborate your answer?
Message 18 of 32
(2,146 Views)
Just open up the Example Finder (Help->Find Examples) and do a search for "subpanels".  That should tell you everything you need to know.
GCentral
Message 19 of 32
(2,142 Views)
Use Vi server to call the plugin vi and use the display subpanel for the front panel of the plugin.  This will allow the main vi to run as normal and allow interaction with the other vi's front panel.
Message 20 of 32
(2,137 Views)
