04-07-2011 09:27 PM
I means its a 'VI snippet'. You can drag the png to a block diagram. Read about it in the help if you have a recent edition.
04-07-2011 09:39 PM
I see. I've got a good lesson from you.
But too bad, my Lv8.5 doesn't support this.
Thanks ya.
04-08-2013 06:51 AM
@ericward wrote:
I still have no idea of why a usb barcode reader should not be a test class device.
They could be, if the manufacturer chose to make it that way.
From http://digital.ni.com/public.nsf/allkb/044FA220F32774ED86256DB3005850CA
USBTMC allows instrument manufacturers to upgrade the physical layer from GPIB to USB while maintaining software compatibility with existing software, such as instrument drivers and any application that uses VISA. This is also what the VXI-11 protocol provides for TCP/IP.
It is important to note that not all USB devices are USBTMC compliant. The device manufacturer has to add the support in the device firmware to support USBTMC. Traditional instruments (such as DMMs and scopes) with USB ports are most likely to support USBTMC. Refer to the instrument's documentation to determine if it is USBTMC compliant.
04-23-2014 10:03 PM
Thanks so much for your info. It might be simple for you but your info saved me 🙂
04-28-2015 09:24 AM
Hi Dennis_Knutson,
I tried the string control idea with the bar code scanner and it works. My problem is that I have to put mouse cursor on the box first in order to input the bar code. Is there a way to program so that Labview automatically knows which string control box to input the bar code without focusing with mouse cursor ?
Fliu
04-28-2015 09:28 AM
Sounds like you are looking for the Key Focus property for your input string.
04-28-2015 10:04 AM
Thanks for your reply. I created a key focus property node from the string control. The key focus property node has an T/F output. I am not sure how to wire this so that it is always true.
04-28-2015 10:37 AM
10-26-2018 06:03 AM
What is ps2 can u explain here??
10-26-2018 08:07 AM - edited 10-26-2018 08:08 AM
You are replying to an 11 year old thread.
If you don't know what a PS2 keyboard is, don't worry about it. If you haven't seen one by now, you'll probably never see one.
https://en.wikipedia.org/wiki/PS/2_port
PS2 is a type of connector used for PC keyboards and mice years ago. After USB came out, and truly took over and became "universal", PC's stopped having PS2 ports, and keyboard and mice manufacturers stopped making PS2 devices.
