how can i use shared variable PC to myRIO
Hi i am currently using Labtop, SICK's LMS100 (LiDAR) and myRIO for actuating my rover.
currently i am receiving LMS100's data through PC and i want to send the "distance" data to myRIO, but I can't send the data PC to myRIO.
as you can see in picture 2, I want to send 3 variable into myRIO, but in picture 3, the variable is not sending properly
and i searched lots of solutions and i disabled all my fire-walls, still cannot send the data to myRIO.
I also tried to use global variable, but it has same result.
how can i share the variable with PC to myRIO?
(2,910 Views)
cant upload the picture...
(2,909 Views)
Accepted by topic author Pikles
Put indicators on the shared variable error outputs to see what they say.
(PS:  The pictures are only slightly helpful.  It is impossible for us to read Chinese or Japanese, whichever those characters are.):smileywink:
(2,896 Views)
Hello
i changed the name of shared variable into english, and it magically work!
thank you for your advice 🙂
(2,878 Views)
I'm glad I inadvertently helped you solve the problem.
I'm guessing those characters need unicode to be able to be displayed.  LabVIEW often has difficult with Unicode, and I would certainly believe the code that underlies Shared Variable communication to make it work would have issues with it.
Changing it to English must have eliminated the problem.
(2,873 Views)
