06-02-2009 05:01 PM
I have ni60008 and DC power supply and DUT.
Aim of my project is to reset the DUT by switching OFF and ON the power supply 12 to 24v DC.
My question is , how can i switch ON and OFF the power supply (mim 12vDC) using ni6008.
Could you please help me.
Solved! Go to Solution.
06-02-2009 06:07 PM
06-02-2009 06:37 PM
hi,
i want to send a command fron labview program to turn off or on the power supply MP3086
through ni6008.
is it possible to do ?
06-02-2009 08:18 PM
06-03-2009 03:13 AM
Without a manual it is hard to say. But perhaps you can get a another power controllable from remote in some way for your school project
06-03-2009 04:33 AM
06-03-2009 04:55 AM
06-03-2009 09:18 AM
06-03-2009 05:49 PM
hi,
Thank you for your reply.
let me explain in detail about my project.
I am using 3rd party usbCAN , DUT, 12v DC power supply cable with 50mA current. I am sending /receiving SDO messages from the DUT.
I have few specifications in my test, which needs to switch OFF and ON the DUT to read the correct data back from the DUT, because after switching OFF/On the power, DUT reboots and reinitialises. which i am doing now by switching OFF/ON the power.
which i dont want to do. I want to do it automatically by using labview.
And i have no idea ,how to use relay 9481, because i dont have ni daq to insert the relay. hoe it will switch OFF/ON the power?
06-03-2009 08:17 PM
Nobody mentioned the 9481, so I don't know how that came into play. Are you saying you have one of these, or are you asking if that's what you need to use? If you have one then it can be used as the relay to connect/disconnect power to the DUT. If not, is this something that someone suggested to you, or something you found on your own? Either way, it's way overkill. As mentioned, if the power supply has no communication interface, and no other means of control and/or activation via a connector, then the only thing you can do is to use a relay to connect/disconnect power to the DUT. You need to select an appropriate relay to handle the voltage and current, and you need to be able to control the relay. Typically this is done via a simple relay driver, such as a transistor, though there are other means.
If you do a search in this forum on controlling relays you'll find lots of hits, as this question comes up a lot.
