06-30-2009 12:35 AM
Hi all,
I need to update the datas read from excel sheet in labview front panel in same format( as a spreadsheet). I placed the spreadsheet in front panel from activeX object. but i could not insert the data inside it. Because the read data from spread sheet is 2D string array but the spreadsheet in block diagram is refnum indicator. what should i do to place the data in Spreadsheet in labview front panel.
Thanks in advance.
06-30-2009 01:44 AM
Hi ragupathi,
you have to use property and method nodes to work with the ActiveX control.
Mike
07-01-2009 08:25 AM
