05-13-2019 08:10 AM
hello,
can anyone help me with this issue i would like to move piezo from 0 to 80µm in 80steps with one click? i able to move manually by changing the values but it needs to be done automatically with one button.
thanking you in advance.
Solved! Go to Solution.
05-13-2019 08:35 AM - edited 05-13-2019 08:36 AM
05-14-2019 05:41 AM
Hai GerdW
i want to create start and end positions i.e i would be able to change the values as required for example if I say start position as 10µm and end Position as 30µm and should happen in that way for any number.
present I used a numeric indicator with that I can only change value. can u help me with this what commands should i use. if possiböe can u please attach example VI how to create start and end commands.
i attached Vi image u can look at once.
thanking you.
05-14-2019 06:54 AM
Hai
I want to create start and end positions i.e I would be able to change the values as required. example- if I say start position as 10µm and end Position as 30µm and should happen in that way for any number.
I used a numeric indicator with that I can only change value. can u help me with which commands I can control start and positions of the device.
if possible can u please attach example VI how to create start and end commands.
I attached Vi image u can look at that.
thanking you.
05-14-2019 10:04 AM
You attached "invisible VI Image". Attach no Image, attach a VI (please).
05-14-2019 10:05 AM
i attached can u look over it
05-14-2019 10:23 AM
You say you used an indicator, but your picture has a control circled. If you would like to limit the range of values accepted for the control, right-click on the control and go to Properties. There should be a Data Entry tab which will allow you to define the value limits of the control and how to respond to values outside those limits.
Also, please don't post pictures of code. Post the actual VI. Pictures are often (usually) not descriptive enough for anyone to be able to help you.
05-14-2019 12:52 PM
