how can i know weathre the perticular vi is opened?
Hi... From main vi, how can i know perticular vi is opened or not?
Thank oyu,
Ranjith
(3,172 Views)
Hi Ranjith,
there's a property node "Frontpanel Window: Open" (or "Frontpanel Window: State") to check the current state of the vi...
Message Edited by GerdW on 07-09-2008 12:13 PM
(3,167 Views)
I am opening one new sub window from main vi. i need to know the status of sub vi in main window. My sub vi doesnt have any inputs or outputs. it runs seperatly after opening it.
ranjith
(3,151 Views)
Hi ranjith,
you can use the "Open Vi Reference" function. Connect a string constant to it and insert the vi name into it. If the vi is in memory you will get the referece to this vi and you can check the state or the visibility. If you get an error, then the vi is not in memory and not running.
Hope it helps.
Mike
(3,147 Views)
