how can i capture image from tv card [AVerTVStudio203(M168)]
Dear all,
i am new at LabView programming, i found some topics on the forum but i can't find the exact solution.
My test system consists of
1] software [ Labview 8.5 ]
2] tv card [AVerTVStudio203(M168)]
3] avertv [viewing and recording software of the tv card]
4] dvb- s receiver (set top box to receive satellite signals)
tv card has 3 inputs
 1] 75 Ω TV Antenna Input ,2]Composite (RCA) video input, 3] S-Video
receiver is connected to tv through composite rca connection.
My question is ?
Can i take a snapshot, capture a photo with this configuration using Labview ?
Best Regards
(4,305 Views)
Hi hldn,
yes i´m sure you can, because you can always do a screenshot and then you got it. It could also be possible that your tv program has ActiveX support.
Mike
Message Edited by MikeS81 on 04-01-2008 04:31 PM
(4,294 Views)
how can i do a screenshot from labview,
i should do everything from labview,
i should take this snapshot photo, and compare it with reference "jpeg" files, to see if the stb works or not
(4,288 Views)
Hi hldn,
for more information about making a screenshot in labview see this thread: http://forums.ni.com/ni/board/message?board.id=170&message.id=312631#M312631.
Mike
(4,272 Views)
Hi hldn,
for special questions about your problem, i think we should use this thread. Smiley Happy
Mike
(4,254 Views)
sorry of course i want to obey the forum rules
thanks but i got the attached error message,
0] how will i check that all the pathes to the dll correct,
0] will i edit these pathes, or move the files to that folders,
where can i find a brief explanation for this, and since i am very new in labview some more questions
1] i have found one more application for viewing analog sound by labview using the on board sound card waveio042.zip
my question is it possible to view the video signal like this by the help of tv card or graphics adaptor of the pc ?
2] if not i will try to use screenshot and image processing, the question is
how can i make this two codes , one for audio and  video , run one after another,
and also will i need extra sw for image processing by labview
best regards
(4,247 Views)
Hi hldn,
if you download the LV8.0 version it could be that there are some error lines are broken. The path to the dll has to be the right one to the kernel32.dll and the user32.dll. You will find both in your windows system directory. connect the error lines and it should work.
Mike
(4,242 Views)
