05-13-2020 11:10 PM - edited 05-13-2020 11:20 PM
After buiting the exe file, "Data Logging" is not active, they are gray out in the menu bar (under Operate tag).
Please let me know how can I activate it ?
05-14-2020 12:54 AM
Hi keisdad,
It would really help when you would show an image of what you are talking about!
Which "Data Logging" item are you talking about?
Which menu bar are you talking about?
What is an "Operating tag"?
05-14-2020 01:10 AM
Hi, You need to insert the vi "write to measurement file" and link it to your signal for logging. In your control panel, look under file i/o menu for the file. After that, drag the icon into your control loop. Link up your signal to be view or log into the signal input of the "write to measurement file"icon. Create a control button to the enable input of the icon. Double click on the icon to set the log file type and destination of the logging file. Compile your whole vi into the exe file. Run exe and test it out.
For more info, search for TDMS in labview help or look for the below vi.
TDMS Express Write Data (Time and Frequency Domain) VI: labview\examples\File IO\TDMS\Express Read and Write
05-14-2020 01:42 AM
I attached an image file what shows I am talking.
Because this is vi which I made, it shows Data Logging is active.
But exe file after built, Data Logging becomes gray out.
