> i want to create a color table for a 8 bit bitmap.The color table is
> the input of "write bmp file.vi". how can i make it?
> thanks!
There is a color control on the front panel numerics palette. A color
in LV is a four byte xRGB formatted number. So you can make an array of
the color numerics and set them by hand or format the numbers however
you like. If unwired it will use the LV color palette which is pretty
much the HTML palette.
Greg McKaskle
