how can I generate C code from vi
I have a complicated VI with several subVIs and I've to create a c code to increase the program speed and transfer rate of data.
This VI is working with a can card to transfer data.
In future I've to implement this code on a micro.
(4,954 Views)
The reason for performance trouble is often not Labview but the programmer. I suggest you post your code. Then we may take a look at at it and give you some advice
Message Edited by Coq Rouge on 05-03-2010 09:48 AM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,937 Views)
Unfortunately, it’s too huge to be mailed!
But the attachment is a part of the main VI.
As I noticed before I have to convert it into a C code for implementation on a micro
(4,907 Views)
poori wrote:
As I noticed before I have to convert it into a C code for implementation ona micro
 What is a micro???
Are you looking for LabVIEW embedded?
(4,896 Views)
Looking into your code reveals some places where you can improve performance. For instance, you can easily remove all variables (ALL! Really!) which will improve performance for sure.
On the other hand, i see the only reason to get C code from this in order to execute the whole application on a uController.
Depending on the uC, you can use the LV Embedded Module.
hope this helps,
Norbert
Norbert
Expert: Geometry
(4,895 Views)
I mean microprocessor!
I don't know any about labview embeded, does it convert the vi into a code?
(4,886 Views)
The code looks relatively good, with the exception of using all those unnecessary Local Variables.  You can wire directly to the indicators.  Plus, why not use the Error Out indicator (cluster) that already exists?
(4,867 Views)
