how can I convert a XY graph to tabular data
Can you please help me. I had a XY graph of motor counts versus intensity. How can I see the graph values in tabular form.Please help me
(3,042 Views)
Use Unbundle function of cluster. You will get two separate array, one of motor counts and other one is of  intensity. Then using build array function you will get a 2D array.
I hope, I got your question right.
Thanks & Regards,
Manisha
(3,037 Views)
What ever you said will not work, because after unbundling, if give those elements to the build array function, the result is a 1d array, thus what to do, since table is a 2d arry. Please help
I
(3,027 Views)
I have attached an example. I hope it helps.
Thanks & Regards,
Manisha
(3,010 Views)
in your example its a 2d data but when i'am putting thet build array its a 1d array. So we have to change output property or something please reply
(2,999 Views)
Please post your code so that everyone can understand what you are trying to explain.
Thanks & Regards,
Manisha
(2,996 Views)
