09-06-2005 07:23 AM
I want to run a RS485 based VI on a blind server. The client PC must be
able to see and control the front panel (the client has the runtime engine
only installed).
I have tried to use the labVIEW web server, and have followed the steps
outlined in the help files also a ltrpub document (on the devzone).
I am only able to see the htm document without the embedded front panel.
What should I be doing to achieve my desired goal, can webserver give me
this control or should I be tackling the problem by another method?
09-06-2005 10:32 PM
How about a client that uses the VI reference to the remote vi to place its front panel in a subpanel on the client?
Mike...
09-07-2005 02:09 AM
Hi Mike,
Sounds great,
I run LV6.1 (full dev) and this is my first venture into networking with LV. The client has only the run-time engine installed, would this prevent using the vi reference?
By sub panel do you mean something like a VBasic GUI?
Do you know of any code or document that would demonstrate this?
sorry you are dealing with a Welsh electronics engineer trying to be a softie!!
Alan
09-07-2005 08:50 AM
09-07-2005 09:11 AM
Hi MarkLee,
I couldn't see your message, please try again
09-07-2005 09:17 AM
