how I can examine whether the hardware was successfully installed
hallo evryone,
one week ago, i got the testing set of NI and i have installed the software for the hardware (PXI-4110 , PXI-4065, PXI-GPIB), however if I want to use the DMM , I get an error message "NO DEVICE found"
is there any  possibility  to examine if the hardware was successfully installed or not
thank you in advance
Toni
(2,622 Views)
Toni,
Use Measurement and Automation Explorer (AKA MAX) to examine your hardware configuration.  Under DEvices and Interface you should find a item called PXI System.  This should show you your hardware configuration including the device name.  An alternative is to open LabVIEW and drop down and Express VI for DAQ.  You should be able to browse for your PXI Chassis and DMM card.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,604 Views)
Hi Matthew
i used the measurement & Automation like u told me and i found the name of the 2 Cards with a strange (X) is this normal or i have to reinstall the software again !!!!
plz take a look at the attached Pic. to understand what  i mean
thank you
Toni
(2,599 Views)
Yes, "X" is bad.  You should find the cards under PXI instead of DAQ.  I haven't done much with PXI but I would reinstall the drivers.  If you have an DEvice Driver CD(s) I would reinstall and make sure all PXI options are enabled.
Matthew Fitzsimons
(2,596 Views)
