high frequency data sampling one at a time
@kumv10 wrote:
The 'Write to measurement file' task that I threw into the loop slowed it down quite a bit
The way around that is to use a Producer/Consumer architecture.
@kumv10 wrote:
Because high temperatures are undesirable for the system. So if a rapid transient takes place and the temperature spikes, I want to be able to take immediate action and cut off power to a certain module. This is essentially a demonstration of a safety mechanism.  So the 'task' being perfomed as I mentioned in my first post, is the shutting off of power.
When safety is the concern, Windows should be nowhere near the system.  This is a task for cRIO.  And based on what I just skimmed through in this thread, you can do almost everything in the FPGA (which is where the real safety critical code should be).
Message 11 of 11
(825 Views)
