10-22-2011 03:47 AM
hi guys
I posted this question berore but I could not find the answer. I attached a jpeg file and I could not find what it is and how to use one spot that is bordered by red frame. could you tell me how to do it?
10-22-2011 04:21 AM - edited 10-22-2011 04:21 AM
guys I have just solved my problem. first I created a control and after it I changed it to constant.
10-22-2011 11:58 PM - edited 10-22-2011 11:58 PM
Then why did you start a new message thread with the same question?
For reference, the question was originally asked and answered here.
10-23-2011 12:44 AM
If u got the answer, Mark the Solution..
10-23-2011 03:11 AM
I have just marked it.
10-23-2011 03:19 AM - edited 10-23-2011 03:23 AM
In the previous topic I cannot find any question till the answer of a member named Darin.K. When I could not find the solution under that topic I decided to write a new one. After a while Darin.K - after about 5 hours- wrote the answer under the previous topic and I marked it as a solution and I wrote a message under the new topic(that one). Maybe you are right I could not think about embeeding the link of the previous topic (you linked it as "here" above) to the new one and marking it a solution but if you look at the date and time you can clearly understand what it is. Thank you all again.
10-23-2011 06:48 PM
Yes. Darin gave you the answer to your question 5 hours after you asked it in that thread.
But you waited another 19 hours after that (which I saw by looking at the dates and times) to ask the same question again even though Darin already gave you the answer. No reason to start a new thread.
